Aktuelle Zeit: Do 16. Mai 2024, 18:46
Blade Composition List-Furnieraufbauten v. Wettkampfhölzern
  • Verein: Out Of The TT-Circus
  • Spielklasse: Ruhestand
BeitragSa 14. Jun 2014, 11:17
Habe ich zufällig im OOAK-Forum gefunden.
Just stumble on this blades info: Some allready are listed some are not:
Adidas V1.3 5 ply hinoki-awan-kiri-awan-hinoki
Adidas Avenger Carbon 5+2 ply walnut-tanne-carbon-ayous-carbon-tanne-walnut
Adidas Challenge Speed 7 ply limba-ayous-ayous-ayous-ayous-ayous-limba
Adidas Avenger 7, 7 ply walnut-ayous-tanne-ayous-tanne-ayous walnut
Adidas Avenger 5, 5 ply walnut-tanne-ayous-tanne-walnut
Andro CS7 Pro OFF: 7 Ayous Furniere (alle gleich dick) CS=Christian Süss
Andro CS7 Tour OFF: Limba-Ayous-Ayous-Ayous-Ayous-Ayous-Limba
Andro CS7 Velocity OFF+: Hinoki-Ayous-Ayous-Ayous-Ayous-Ayous-Hinoki
Andro C. Suss Hinoki All+ : hinoki - ayous - ayous - ayous - hinoki
Andro C. Suss Hinoki Off : hinoki - ayous - ayous - ayous - hinoki
Andro Kinetic ALL+ : limba - limba - abachi - abachi - limba - limba
Andro Kinetic Supreme Z-Fiber/Hinoki Off-: Hinoki-Zlf-Ayous-Kiri-Ayous-Zlf-Hinoki
Armstrong Tactic: Nussbaum - Limba - Abachi - Limba - Nussbaum
Avalox BT555 : limba - spruce - ayous - spruce - limba
Avalox P500: koto - spruce - ayous - spruce - koto
Avalox P700: limba - meranti - ayous - ayous - ayous - meranti - limba
Banda Waldner: Limba-Spruce-Abachi-Spruce-Limba
Banda Offensiv: Limba-Spruce-Abachi-Spruce-Limba
Butterfly Adolescen: limba - limba - ayous - limba - limba
Butterfly All Hinoki 5: 5 Kiso-Hinoki Furniere
Butterfly All Hinoki 7: 7 Kiso Hinoki Furniere
Butterfly Amultart: hinoki - zlc - kiri - zlc - hinoki
Butterfly Balsacarbo X5: basswood - carbon - balsa - carbon - basswood
Butterfly Defence II: 3 Weide Furniere
Butterfly Gergely alpha: cypress - carbon laminate - kiri - carbon laminate - cypress
Butterfly Gergely Tamca 5000: cypress - carbon laminate - kiri - carbon laminate -
cypress (7.0mm)
Butterfly Innerforce ALC: limba - limba - alc - ayous - alc - limba - limba
Butterfly Innerforce ZLC: limba - limba - zlc - ayous - zlc - limba - limba
Butterfly Innerforce ZLF: limba - limba - zlf - ayous - zlf - limba - limba
Butterfly Jonyer-Hinoki: 5 ply all hinoki
Butterfly Joo Se Hyuk: planchonello - poplar - kiri - poplar- planchonello
Butterfly Jun Mizutani: limba - zlc - limba - kiri - limba - zlc - limba
Butterfly Kazan: hinoki - walnut - balsa - walnut - hinoki
Butterfly Keyshot Light : ayous - arylate - kiri - arylate - ayous
Butterfly Kim Taek Soo: hinoki 10.3
Butterfly Kiso Hinoki V: 5 Kiso Hinoki Furniere
Butterfly Kiso Hinoki VII: 7 Kiso Hinoki Furniere
Butterfly Kong Ling Hui: koto - spruce - ayous - spruce - koto
Butterfly Korbel Sk7: Limba - Abachi - Abachi - Abachi - Abachi - Abachi - Limba
Butterfly Kreanga Carbon : hinoki - ULC - kiri - ULC - hinoki
Butterfly Liu Shiwen: limba - limba - zlf - ayous - zlf - limba - limba
Butterfly Maze Passion : Limba - Glasfiber - Spruce - Abachi - Spruce - Glasfiber - Limba
Butterfly M. Maze: limba - alc - limba - ayous - limba - alc - limba
Butterfly Oh Sang Eun : koto - koto - ayous - koto - koto
Butterfly Primorac: limba - limba - ayous - limba - limba
Butterfly Primorac Carbon: cypress - carbon laminate - kiri - carbon laminate - cypress
Butterfly Pter Korbel: limba - limba - ayous - limba - limba
Butterfly Photino: hinoki - zylon - kiri - zylon - hinoki
Butterfly Schlager Carbon OFF+: cypress - carbon laminate - balsa - carbon laminate -
cypress
Butterfly Schlager Prezision : Koto - Spruce - Abachi - Spruce - Koto
Butterfly Timo Boll Spirit: koto - alc - limba - kiri - limba - alc - koto
Butterfly Viscaria: koto - alc - limba - kiri - limba - alc - koto
Butterfly Zhang Yining: limba - limba - ayous - limba - limba
Cornilleau Hinotec ALL+ : hinoki - limba - ayous - limba - hinoki
Cornilleau Hinotec OFF- : hinoki - limba - ayous - limba - hinoki
Cornilleau Hinotec OFF : hinoki - limba - kiri - limba - hinoki
Cornilleau Hinotec OFF+ : hinoki - carbon - kiri - carbon -hinoki
Dawei GTS: hinoki - arylate/carbon - ayous - arylate/carbon - hinoki
Dawei Wavestone: limba - arylate/carbon - ayous - arylate/carbon - limba
Donic Alligator Combi:limba - acajou - balsa - abachi - ash
Donic Appelgren Allplay: limba - limba - ayous - limba - limba
Donic Appelgren Dotec Control: Limba-Dotec-Ayous-Dotec+Balsa-Ayous-Dotec-Limba
Donic Baum Sawtec: ayous(0,8mm) - ayous(1,5mm) - ayous (2,0mm) - ayous(1,5mm) -
ayous(0,8mm)
Donic Burn All+: mahogany - awan - kiri - awan - mahogany
Donic Burn Aratox: Koto-Kiri-Aratox-Kiri-Aratox-Kiri-Koto
Donic Burn Aratox RS: Mahagoni-Kiri-Aratox-Kiri-Aratox-Kiri-Mahagoni
Donic Burn Carbotox: Mahagoni-Kiri-Carbotox-Kiri-Carbotox-Kiri-Mahagoni
Donic Burn Off-: mahogany - awan - kiri - awan - mahogany
Donic Burn Off: mahogany - awan - kiri - awan - mahogany
Donic Carbo System Off: Koto-aramid/carbon-Ayous-Kiri-Ayous-aramid/carbon-Koto
Donic Defplay Classic Senso: Koto-Ayous-Balsa-Balsa-Ayous-Koto
Donic Dicon: limba - spruce - ayous - spruce - limba
Donic Dima Sawtec: koto(0,8mm) - kiri(1,0mm) - kiri(2,5mm) - kiri(1,0mm) -
koto(0,8mm)
Donic Liping Kitex: kiso hinoki - ayous - texalium - kiri - texalium - ayous - kiso hinoki
Donic Opticon RS: beech - ayous - balsa - ayous - beech
Donic Persson Carbotec: koto - carbon/glass - tanne - kiri - tanne - carbon/glass - koto
Donic Persson Dotec Off: Hinoki(0,6mm)-Dotec-Koto (0,6mm)-Dotec+Balsa(5mm)-Koto
(0,6mm)-Dotec-Hinoki (0,6mm)
Donic Persson Exclusive Off: limba - koto - balsa - koto - limba
Donic Persson Powerallround: Limba-Limba-Abachi-Limba-Limba
Donic Powerplay : koto - foil - ayous - ayous - ayous - foil - koto
Donic Waldner: Limba-Spruce-Abachi-Spruce-Limba
Donic Waldner Allround : Limba-Limba-Abachi-Limba-Limba
Donic Waldner Diablo Senso: Limba-Glasfiber-Ayous-Glasfiber-Limba
Donic Waldner Dicon: Limba-Spruce-Abachi-Spruce-Limba
Donic Waldner Dotec AR: Limba (0,6mm)-Dotec-Limba (0,6mm)-Dotec+Balsa(4,5mm)-
Limba (0,6mm)-Dotec-Limba(0,6mm)
Donic Waldner Dotec Carbon: Limba(0,6mm)-Limba(0,6mm)-Carbon-Balsa-CarbonLimba(0,6mm)-Limba(0,6mm)
Donic Waldner Dotec Hinoki: kiso hinoki - kiso hinoki - kiso hinoki
Donic Waldner Offensiv (40): Limba-Spruce-Abachi-Spruce-Limba
Donic Waldner Senso Carbon: Limba-Limba-Carbon-Ayous-Carbon-Limba-Limba
Donic Waldner Senso Ultra Carbon: Limba-Abachi-Carbon-Abachi-Carbon-Abachi-Limba
Donic Waldner V1/V2 : Limba-Spruce-Abachi-Spruce-Limba
Donic Wang Xi Dotec Control Plus: Limba(0,6mm)-Ayous(0,6mm)-Dotec-Kiri(3,5mm)-
Dotec-Ayous(0,6mm)-Limba(0,6mm)
DHS H-WL: limba - meranti - ayous - meranti - limba
DHS Hurricane Hao: koto - spruce - ayous - spruce - koto
DHS Hurricane King: koto - spruce - ayous - spruce - koto
Yinhe Bogen: American Hinoki-Carbon-Kiri-Carbon-American Hinoki
Yinhe Arbalest Thor: limba - carbon - balsa - carbon - limba
Yinhe Lanze: limba - carbon - balsa - carbon - limba
Yinhe Speer: limba - carbon - balsa - carbon - limba
Galaxy/Yinhe T10: cypress - carbon - balsa - carbon - cypress
Galaxy/Yinhe T11: limba - carbon - balsa - carbon - limba
Galaxy/Yinhe M-4: limba-limba-ayous-limba-limba
Hallmark Aurora: Limba-Nussbaum-Balsa-Abachi-Koto
Hunter Hawk: poplar - bass - poplar (4.3mm)
Joola Chen Weixing: limba - koto - black cloth - kiri - black cloth - koto - limba
Joola Fetzner Carat: Mahagoni-Mahagoni-Fichte-Mahagoni-Mahagoni
Joola Fever: limba - carbon meliorate - ayous - kiri - ayous - carbon meliorate - limba
Joola K5 : limba - limba - ayous - limba - limba
Joola Rosskopf Fire ( alt ): Limba - Limba - Abachi - Limba - Abachi - Limba - Limba
Joola Rosskopf Force: hinoki - carbon - kiri - carbon - hinoki
Joola Trix Fast: cypress - spruce - x (balsa/carbon) - spruce - cypress
Joola Trix Medium: samba - enzo - lilac - samba - enzo - samba
Joola Wing Fast: hinoki - ayous - kiri - ayous - hinoki
Joola Wing Medium: koto - ayous - kiri - ayous - koto
LKT Ayous Hinoki: Ayous-Hinoki-Ayous-Hinoki-Ayous
LKT Instinct: Ayous-Basswood-Ayous-Basswood-Ayous
Nexy Color: hinoki - spruce - ayous - spruce - hinoki
Nexy Spear: limba - spruce - ayous - spruce - limba
Nimatsu Tsunami Combi Attack: (0,6mm) limba - (2,0mm) balsa - (6,0mm) balsa -
(2,0mm) balsa - (0,6mm) ayous
Nittaku Acoustic: limba - limba - tung tree - limba - limba
Nittaku Clout: 5 Kiso Hinoki Furniere
Nittaku Ludeack: limba - ayous - ayous - ayous - ayous - ayous - limba
Nittaku Rutis: walnut - GCarbon - Kiri - GCarbon - walnut
Nittaku Septear: 7 ply all hinoki
Nittaku Violin: white ash - white ash - kiri - white ash - white ash
Nittaku Wang Nan: koto - spruce - ayous - spruce - koto
Stiga Allround Classic: limba - ayous - ayous - ayous - limba
Stiga Allround Evolution: limba - ayous - ayous - ayous - limba
Stiga Clipper: limba - ayous - ayous - ayous - ayous - ayous - limba
Stiga Ebenholz NCT V: ebony - spruce - ayous - spruce - ebony
Stiga Energy Wood: limba - ayous - ayous - ayous - limba
Stiga Intesity NCT: Nussbaum-Fichte-Abachi-Fichte-Nussbaum
Stiga Offensive ( von ca. 1982 bis ca. 1986 ): Nussbaum - Spruce - Abachi - Spruce -
Nussbaum
( die Version mit dem gefärbten Koto Deckfurnier kam erst ab 1986/87 )
Stiga Offensive Classic Old: koto - spruce - ayous - spruce - koto
Stiga Offensive Classic New: (black walnut/limba) - spruce - ayous - spruce - (black
walnut/limba)
Stiga Offensive Evolution : Nussbaum -Limba(rot gefärbt)- Abachi - Limba(rot gefärbt)-
Nussbaum
Stiga Tube Offensive: limba - ayous - ayous - ayous - limba
Sword V6: Limba-Ayous-Ayous-Ayous-Limba
Sword V8: Koto-Hinoki-Ayous-Hinoki-Koto
Taico 80 : Limba - Limba - Abachi - Limba - Limba
Taico 100 : Hinoki - Rosenholz - Abachi - Rosenholz - Hinoki
Taico 300 : Limba - Nussbaum - Abachi - Abachi - Abachi - Nussbaum - Limba
Tibhar Charly Roesch : Abachi - Abachi - Abachi - Abachi - Abachi - Abachi
Tibhar IV-L: ayous - ayous - ayous - ayous
Tibhar IV-L Light Contact: ayous - ayous - ayous - ayous
Tibhar Lucjan Blaszczyk : limba - limba - limba - limba - limba
Tibhar Marcos Freitas 7 ply limba-carbon arylate-ayous-kiri-ayous-carbon arylate-limba
Tibhar Inca hinoki-aramid carbon-kiri-aramid carbon-hinoki
Tibhar Furious 7 ply limba-ayous-limba-ayous-limba-ayous-limba
TSP Break 9: 9 ply all hinoki
TSP Break 11: 11 ply all hinoki
TSP Phoenix Fire OFF: Koto - Awan - Kiri - Awan - Koto
Ulmo Duality: (FH=>BH) samba - balsa - poplar - poplar - poplar - balsa - mahogany
Xiom Amadeus: hinoki - limba - ayous - ayous - ayous - limba - hinoki
Xiom Amati : limba - limba - carbon fleece - ayous - carbon fleece - limba - limba
uncertain
Xiom Aria: limba - spruce - ayous - spruce - limba
Xiom Control: hinoki - aramid carbon - kiri - aramid carbon - hinoki
Xiom Fuga: koto - spruce - ayous - spruce - koto
Xiom Hayabusa Zi: koto - limba - Zephylium - ayous - Zephylium - limba - koto
Xiom Ignito: hinoki - energy/zeta carbon - kiri - energy/zeta carbon - hinoki
Xiom Jazz: hinoki - koto - ayous - koto - hinoki
Xiom Magellan:Hinoki-Limba-Ayous-Limba-Hinoki
Xiom Maximus: limba - limba - ayous - limba - limba
Xiom Ovid : limba - limba - ayous - limba - limba
Xiom Powerlite Plus:-10.3mm Kiso Hinoki
Xiom Stradivarius: koto - aramid carbon - ayous - kiri - ayous - aramid carbon - koto
Yasaka Allround Plus: 5 Espen Furniere
Yasaka Extra: anegre - limba - ayous - limba - anegre
Yasaka Extra Offensive: walnut - spruce - ayous - spruce - walnut
Alternativ auch für andere Hersteller:
Stump’s Blade composition list. Part 1: A…F
http://stumpof.blogspot.ru/p/stumps-bla ... ition.html
Stump’s Blade composition list. Part 2: G…R
http://stumpof.blogspot.ru/p/stumps-bla ... ist-j.html
Stump’s Blade composition list. Part 3: S…Z
http://stumpof.blogspot.ru/p/stumps-bla ... st-kz.html
Version: 04.04.2014
http://www.online-translator.com/?prmtlang=de
Quelle: http://ooakforum.com/viewtopic.php?f=43 ... &start=135
Re: Blade Composition List-Furnieraufbauten v. Wettkampfhölz
BeitragSa 14. Jun 2014, 13:10
Das ist schon mal ein Anfang.
Obwohl ich bezweifele, dass beim Clipperwood, die rote Faserschicht Ayous ist.
HOLGI
  • Spielklasse: Hobbit Klasse
BeitragSa 14. Jun 2014, 15:47
Cogito hat geschrieben:Das ist schon mal ein Anfang.
Doch das passt schon, das ist tatsächlich rot eingefärbtes Abachi. Hm, ob das Färbemittel die Eigenschaften beeinflusst?
BeitragSa 14. Jun 2014, 17:33
Nicht, wenn es Läuseblut ist. :mrgreen:
BeitragSo 15. Jun 2014, 14:19
Das ist aber so. Das Clipper Wood besteht aus 5 Ayous-Schichten und Limba-Deckfurnier.
Erik07
  • Verein: DJK Bingen-Büdesheim
  • TTR: 1526
BeitragSa 8. Nov 2014, 21:50
zum Persson Powerplay gibt es aber auch Angaben mit Limba Außenfurnier.
ich glaube die älteren Modelle hatten Koto, die neueren hatten Limba.
4 MD!
BeitragSo 9. Nov 2014, 01:11
Noch nie ein PPP mit Limba gesehen ! Ganz klar Koto.
Viscaria, VH Airoc S 2,1mm, schwarz , RH Airoc M 1,7mm, rot
BeitragSo 9. Nov 2014, 10:45
Definitiv Koto :2thumps:
Erik07
  • TTR: 1526
BeitragSo 16. Nov 2014, 22:08
wer weiß wie der Furnieraufbau des Stiga Optimum Sync ist ?
habe eine Angabe gefunden, die war : limba-ayous-kiri-ayous-limba
Wie dick ist das Holz ?
Danke
